Snapping during smooth vertices
posted to: Retopology: Scalp
When I use smooth vertices operation, vertices does not stay snapped on the surface.
I have to select single lines and snap it again on the surface.
Does anyone know why it happens?
  • spikeyxxx replied
    Smoothing is indeed not affected by Snapping, only Move (and Rotate and Scale, if enabled).
    I always do Smooth Vertices, G, Enter. You don't need to select single lines, you can Snap a whole area.
    You can also, use a  Shrinkwrap Modifier, in addition to Snapping. (Enable the On Cage 'triangle icon', to see it in Edit Mode.)
