UI_script doesn't run.
@waylow  , thank you for another excellent course + exercise.
Sorry, I am battling with an issue.
The python script, I can't get it running. I am using Blender 3.0, but I noticed a few recent submissions who, I guess also use this latest version, that don't have this issue.
I followed every step in the 5 Crane Arm Part courses, was very carefully with naming, layering, running the script etc.
Repeatedly tried to make it run, but nope.
this is the error message I get
I choose the Puython type, all others don't accept the Default Value input.
I guess this is also correct inputting the values/names.
Sigh, what did I do wrong :P.
  • Wayne Dixon replied
    Hi Donso,
    The devs seem to always be changing a few things here and there.
    You want to change the 'type' to STRING.  (Python is if you want to run a python command)
    Then create the property with the name "rig_id"
    Don't worry about the value just yet - you need to do that in the next step.
    Once it is created - change the default value of 1.0 to the text "Crane-arm_rig"  and run that script.
    Here's a video of that.
    https://www.dropbox.com/s/se0qlrd96i9aqjx/Crane-UI.mp4?dl=0
  • Don Soarese replied
    Sorry for replying a bit late.
    Thank you, it worked:
