Incorrect gradient scale.
Hi everyone,
I am having a curious problem with gradient scale on the columns :
As you can see, though my white flag position is super low (0.020 !), the white part of the gradient is still very high on the column.
Of course, i thought it was a problem with the object scale, so i Ctrl+A Applied scale, but it didn't solved my problem.
Any ideas ? :)
  • Koala replied
    Well, after a moment of reflexion, i found a solution to my own question. Still, i am not gonna delete the question, but rather post the answer here, as it might be useful for other people. So i noticed that Kent's columns origins were much higher than mine. So i move the origins of all of the columns by selecting the move tool, and choosing "Affect only : Origins" (N menu on the right). The "lowest" point of the gradient followed the origins.
  • spikeyxxx replied
    Indeed, when you are using Object Coordinates, the Origin of the Object is  (0, 0, 0) and the bounding box goes from -1 to 1 in all 3 directions, like this (when the Objects Scale is Applied!):
    The Colorramp clamps all input values to a 0 to 1 range (negative inputs are considered 0 and nubers higher than 1 become 1).
