Cable Edges don't have the same distance
Hi Jonathan
How do you manage to get the same distance by the edge rings?? When I put them into position (still curve), then convert them the edge rings are getting closer at the ends...
thank you, I hope you know what I mean
ps: Or are you just eyeballing  them until it looks alright?
  • spikeyxxx replied
    Hey Martin,
    I think he is just eyeballing it, but you can also use this trick:
    Say you have a Curve:
    Remove the Bevel, Convert to Mesh:
    Use your LoopTools Addon (ships with Blender, but is not enabled by default) > Space:
    that will evenly distribute the Vertices....might slightly change the shape of the Curve, depending on resolution and how unevenly spaced the Vertices were...
    and then Convert to Curve, Bevel:
    and back to Mesh:
  • Jonathan Lampel replied
    Can you show an example of what yours looks like? Spikey is right, I'm just eyeballing it.
  • mastart replied
    Hi Jonathan, thank you, I was could eventually eyeball it and am happy with the result. My bad examples are deleted, nothing left to show :))
    thank you anyway for your time.
    Martin
  • mastart replied
    Thank you Spikey for your time: I eventually could eyeball it and get a decent result...
