Baking normals
Hi, can you use bake normals to create an alpha for sculpting? So you could create like a bas  relief on a model?
  • Jonathan Lampel replied
    Yes, you sure can! Perfect example of a good use case. I wouldn't use an actual alpha channel though as that sometimes causes problems.
  • Joel Wagner(roofoo) replied
    Thanks, will this stamp affect actual geometry on a subdivided mesh, or it it just a visual shader thing?
    It's just a shader thing
    Ok maybe this isn’t the right place to ask but how do I create an alpha image from a 3D object to sculpt and create a 3D printable bas relief, using Blender? Like the new bas relief tool in Zbrush. Thanks
    http://docs.pixologic.com/user-guide/3d-modeling/sculpting/bas-relief/
