Recommended prerequisites
So far I've completed the Basic Tutorials and the Low Poly Rockets course. What other courses would you recommend, if any, as prerequisites before starting this?
  • adrian replied
    Hey bbenza ,
    You have started on the right track.
    Are you happy with your progress so far?
    My tip, what I always and still do, is watch the course through once without opening blender.
    This helps by having an idea of where we're going in each lesson when I then follow along.
    You could take a look at Fundamentals of Mesh Modelling for more modelling practise,
    This is part of the Complete Fundamentals Workflow, which covers also texturing, lighting and animation fundamentals.
    Hope this helps.
    Happy Blending.
  • Jonathan Lampel replied
    I would second that suggestion for the Fundamentals of Mesh Modeling and would also recommend the Fundamentals of Shading and the Fundamentals of Texturing from that series as well since we're going to be doing some node work and texture painting later on in the course. Those should answer a lot of questions before you have them. Good luck!
