Wave texture along the object
Dear community
I am stuck with a wave node setup that should go along the edges/faces.
Does anybody know how to fix this issue? The waves should go along the red lines.
I just can't figure it out
thank you and have a good day
  • mastart replied
  • spikeyxxx replied
    Hi Martin,
    the only way I can think of is to  unwrap and straighten the UV's...something like this:
  • spikeyxxx replied
    There is another way:
    if you use Curves, you get this  (almost) for free:
    You might get some stretching of the UV's:
    in which case you can remove the Bevel of the Curve and turn it into a Mesh (Object > Convert > Mesh, or search for it. I use these conversions all the time and have them in my Quick Favorites..).
    Go into Edit Mode:
     and use LoopTools (Addon) > Space, to even out the Vertices 'without changing the shape':
    and back to Curve with Profile. That should fix the stretching.
  • mastart replied
    Hallo Spikey
    Thank you for your help. I'll deffinitely give it a try... I will let you know :))
