Opening at End of Corridor Instead of Black
posted to: Camera & Lighting
Hello - this is a great project and I'm enjoying putting this corridor together. I've been successful so far, however, when I render, I am not getting black at the end of my corridor. The animation is looping properly, but it is only showing an opening on the other side instead of black. I keep checking the section to see if perhaps I've missed a step.
Please advise what I should double-check or fix to get the correct render.
Thank you.
  • Jeff Lange(jefe317) replied
    The solution is in the next video, the compositing part. The end of the tunnel is faded out in post processing.
  • veenn replied
    Thank you very much. I was able to complete it and the full animation.
