Stabilize stroke is disappeared
I was doing texture painting and suddenly my brush stuck to stabilize stroke and doesn't go back to normal brush. As you can see the option itself is gone somewhere, and hotkey (shift+s) doesn't work either.
How can I make  this feature come back?
  • adrian replied
    Hi jeewon , changing the stroke method will give different options , the stabilize option is available with the spacing, dots and airbrush stroke methods selected. Spacing is the default. If you want a line but want to keep the stabilize option slow down the speed you move the brush, or try change the spacing value slider.
  • Jeewon (jeewon) replied
    That was unbelievably simple solution. Thank you always Adrian!
