Blender 2.9 - Using Skin Modifier Only Breaks Segments into 3 Pieces
posted to: Skin Modifier Base
Hello.  I noticed that when I use the skin modifier, I only get three sections compared to six in the tutorial.  Is it necessary to make some setting adjustments to get the same number of sections?  Thank you.
  • adrian replied
    Hey eennstar , the number of segments is consistent with the distance between verts.
    Notice here 👇 just moving the extruded vert higher, will result in more segments.
  • ennstar replied
    Oh wow, didn't realize it was something that simple to fix.  Looks like if I scale up the reference image by 2, the number of segments matches the video.
    Thank you for the solution!
