Can we use physics for the bed sheet?
Hi, I wanted to represent somewhat realistic folds in the bed sheet. This is difficult to model by hand.. Can I use a physics modifier on a plane and then drop it onto the bed, to have a cool realistic looking bed sheet? I figured this out, but I was wondering if it is allowed as part of the solution method.
Thanks for your help!
  • adrian replied
    You could do that ttomlearning ,
    But the point of this exercise is low poly modeling, getting to grips with low poly will help you later.
    Good luck with it. Look forward to your final result.
  • tomlearning replied
    Thanks for your feedback! Ok, I will only apply the physics to the bed sheet :-) The rest will indeed be purely low-poly modelled.
