To much green/ Extra lighting
Hey I have been working on this for a while in-between classes and work .Using Blender 2.9 I am having an issue with the green Hue from the UFO. Its way to intense. I went into the shading  and tried to fix it using the nodes already on the craft. but its altering the overall look and taking away to much green. I noticed you have some lights added into the scene that were not mentioned. I added some lighting and increased the intensity. that helps a little but its still to green. any ideas? Thanks in advance
  • adrian replied
    Hey rrock99 ,
    Which lights are you saying were not mentioned?
    Double check everything. Check you have nodes plugged into the correct sockets on shaders and in the compositor. You may need to tweek some settings, it can look different from the video if you copy every setting.
    If your still having a problem can you share the file on google drive or dropbox?
