Grunge flips location
Why does the grunge jump from the bottom to the top of the model when I increase the value of my Spread note to more than 0.5?
  • adrian replied
    Check the map range node, make sure you have 'clamp' checked and you haven't inadvertently messed up the to min and to max numbers. I do this sometimes thinking it should be
    from min
    to min
    from max
    to max
    this order makes more sense to me.
