Transform tool use
You used the transform tool and were able to drag the object across the 3d view without going to the object to do it, mine does select tool when I do that how does this work?
    vanzkie This has been changed since the time when @jlampel recorded the lesson video. I've tested it with 2.80 Beta where it worked as in the video you mentioned but in 2.93 Alpha for example it works as you described it with your Blender version.
  • Evangeline Joy Sanchez(vanzkie) replied
    Ok, thanks for the answer :)
