Texture Layer Alpha
I don't understand why when  a new texture layer is added its alpha is plugged into the factor of the RGB mix node. Surely if the alpha is set to zero then that will also mean that RGB node is also set to zero effectively blocking the input to colour 2.
Thanks
  • spikeyxxx replied
    Yes, you are right, but when you start painting on that texture, where you paint  the Alpha is 1 (the paint doesn't have an explicit Alpha channel).
  • John Knops(xpomjohn) replied
    When you explain it, the answer is obvious. Thanks again
