Shader breaks when objects scale is bigger than 1
Hi,
The shader seems to not work when I set object scale to something bigger than 1:
WIth scale set to 10 we have 10 scan lines compared to scale 1:
How can we fix it?
Thanks!
Peter
    scale other than 1 breaks a lot of things in blender...
    the way to approach it would be to scale up\down your object to get "proper" size...
    then apply the scale...
    this is accomplished by "ctrl+A" and choose scale from the drop down...
    this will change the scale setting back to 1 and retain the new size of your object
    and all other operations in blender will be happy!!
    hope this helps
