Non related question (rendering help)
Hi there I made text and animated it. However when I save as PNG sequence render to take into After effects it doesnt keep the surface materials and lighting.  I am using cycles and my GPU.  I have it on transparent as I dont want the background, which works.  Any tips?
  • Jonathan Lampel replied
    Hi, I think this lesson will help - it goes over the difference between what you see in the viewport and what gets rendered out: Rendering Engines and Viewport Rendering - CG Cookie
    You can also ask questions directly on the forum rather than under a lesson if it's unrelated to the lesson.
    Hope that helps!
