I'm having trouble with the nodes in the fog object
My viewport is turning black as soon as I connect the principled volume to the material output
  • Kent Trammell replied
    Are you connecting the principled volume to the "surface" output instead of the "volume" output?
  • patdoc replied
    no I connected the principled volume to the volume in material output
  • spikeyxxx replied
    If you are using Rendered View, with Scene Lights enabled, but with no lights in your Scene...
    You don't give us a lot of information, so we are just guessing...
  • patdoc replied
    here's a screen shot of my view port display. Don't mind the extra window on the right. Sometimes the view port will be dark and sometimes it will be clear
  • patdoc replied
    scene light and scene world were both checked
  • spikeyxxx replied
    The 3D Viewport doesn't give me any information; you already told us that it was black ;)
    And the Shader Editor doesn't show the Fog...
    But if it is sometimes black and sometimes clear, then my guess would be that it is your Graphics driver (that is not up to date).
