pressing f6 only jumps to the last command line/ function you use, if i enter edit mode then pressing f6 only gives me the...
pressing f6 only jumps to the last command line/ function you use, if i enter edit mode then pressing f6 only gives me the option of toggling edit mode. If you move the object out of edit mode via the x,y,z axis arrows it allows you to re-enter translate. was confused for a second thought f6 always would bring you that menu of translate but it doesn't. currently using blender 2.75
  • tyoc213 replied
    Even more, I think you could understand better the "latest command" if you enable the sticky keys for make "tutorials" it always shows the last action too AFAIK.
