[SOLVED] Solid Shading Gone For X-Ray
Before today, I could be editing in solid mode with x-ray on and the faces would be transparent but visible. The faces are no longer visible. Any suggestions on what I might have done to change that?
Further info: This only seems to be a problem in one of the orthographic views. Looks okay in perspective. I don't recall that it worked that way before, but maybe that is the case?
    Is your viewport render mode set to anything other than "solid" shading?
  • Paul Haynes(paulhaynes1955) replied
    Viewport Display? Is set for textured but it's always set for textured. I'm going to do a clean install. I've had problems several times before (of a different nature) that were caused by add-ons. I'm going to see if that works.
    Opening the same .blend file in an updated version of blender had the same result.
    I exported the model, ran "blender_factory_startup.cmd", imported the model and all is well.
    I'm guessing that .blend file was somehow corrupt. No idea. But I'm back in business so I'm a happy camper.
    Thanks for the response.
    I have seen buggy behavior in the textured display when using x-ray. I know that Render display even sends a prompt about compatibility. But corrupt files can also do it. I think corruption happens more often than I like to admit lol.
    Glad you got it sorted though.
