Hi there,
I believe I’m the first person asking this question because I can’t find the solution to it.
I have encountered 2 issues:-
1. My cube won’t change after using the displace modifier (Refer to 27:30 video time).
2. I can't create my planet surface similar to the video (I have followed accordingly to the video instruction)
Below I have attached some screenshots for your reference.
Thank you!
Displace modifier:-
Planet surface:-
1. You probably have your Displacement Texture set to Image or Movie (without specifying an image).
Go to your Textures:
Change the type from Image...:
To another type:
If that is not what your issue was, then maybe the size of your Texture is wrong.
Haven't seen the video, so I can't answer your second question.
