Understanding 3D Transformations: Thanks for this course!
jjedilink  Thank you for this course which will hopefully help me to solve some tricky texturing challenges. I've just seen this example of snake scales where a scale is instanced using particles. I would be happy to be able to visualize myself what's happening there exactly after this course .
    jjedilink Interesting, that "Extrinsic Rotations" in Euler (either done with the "Rotation Manipulator" and the "Transformation Orientation" set to "Global" or directly entered in the "Properties Panel" ) achieve the same final orientation as a rotation around the "Local Axes" of an object if you execute the rotations just in the opposite order of the ones for the "Local Coordinate System".  And thank you for "stretching" my brain 😉👨‍🎓!
