i do not see any vertex showing when I ctrl+right click (Blender 2.79)
i have the same configuration,so when i try to CTRL+right click
  • bitbuilder replied
    Are you in vertex selection mode? 1 on the number bar.
  • spikeyxxx replied
    In 2.79 Blender used right-Click-Select by Default. In that case, you should: (select a Vertex, when you want to extrude it,) move your Mouse Pointer to the desired position and then press CTRL+LMB.
