Smoothing the keyhole part shows visible triangular seams
I want to smooth the keyhole bracket part and when I set the smooth shading, I clearly see the triangular geometry around the keyhole.
Here is the captures of what I see
On my screenshots, I havent added explicit sharped edges on the smoothed capture.
Below, the smoothed mesh
Did I've done anything wrong ? :/
  • spikeyxxx replied
    Try turning on Auto Smooth in the Object Data Properties (green 'triangle'):
  • veltarn replied
    Oh, well... problem solved... :)
    I activated it but brainlessely set it to 180 and  I just figured it out, by reading your answer, that if I set it higher than 60° I start to see seams.
    30 or 40° seems to be the good values, thanks you!
