can't set color to frame
I am trying to give my frame  a color like you do (11.23sec) but all I get is a standard Line....
Any advice or idea what that could be?
Thank you very much
Martin
  • Kent Trammell replied
    Make sure you have the Color box checked?
  • mastart replied
    Indeed it is
    also in  the Preferences I couldn't find anything wrong 😪
    It must be a theme setting then. Check in your User Preferences > Theme > Node Editor > Frame Node
    Make sure the A (alpha) setting is not set to 0. If it is it means it will always be 100% transparent. The default alpha value is 0.8.
  • mastart replied
    God bless you Sir!!!
    thank you!
That course doesn't exist!
