Cannot see the eyes in EEVEE render
I can see the eyes in Storm in Cycles but not in EEVEE. I turned on Screen Space Reflection and also Refraction but I still could not see the eyes. I thought it maybe the lighting so I added a light source and still -nothing. Again, I can see the eyes in Cycles but just not in EEVEE. Are there other settings? I am using the 2.8 version by the way. Any help would be greatly appreciated. Thanks.
  • Wayne Dixon replied
    Hey Steve,
    Have you checked this out?
    https://cgcookie.com/lesson/screen-space-refraction
    If you have, then you'll need to show more info. Maybe some screenshots of your view settings or you can share the actual file.
    (which you can't do directly on the site here I'm afraid, you'll have to upload somewhere on the web and share the link)
  • leatangclan replied
    Hello Wayne,
    Here is a screen shot showing the Screen Space Reflection and Refraction enabled - in EEVEE render. I am not sure if I need to enable other settings; or change some values? It's no biggie as I can render fine in Cycles. Thanks much in advance.
    Hey Steve,
    What does it look like when you use Material Preview Mode?
    When you are in Rendered view you can also drop down the menu and disable World and Lights. That way it will use the in-built HDRs
    But I'm not sure why your eyes aren't visible.
    Hello Wayne,
    Thanks for looking into this but sadly I tried all that and more; nothing worked. It's fine. I can just render in Cycles. It's more important to make get the jump right. I have my hands full with that. Thanks again.
