How to apply Lattice mesh deform?
Hi Chunck, I've parented pizza slice to lattice but failed to deform it. Can you show me how it's done? Thanks.
  • spikeyxxx replied
    If you parented it with CTRL+P select Lattice Deform
    Make sure to first select the Pizza slice and then the Lattice!
    Alternatively add a Lattice Modifier to the Pizza:
    And select the Lattice as Object (in the Modifier). The result is exactly the same with both ways.
    Another thing that can go wrong, is that your pizza slice (or any object) doesn't have enough geometry.
  • Benjamin Lee(relidin) replied
    Thank you for the explanation. It's really fun to play with :)
