Feedback in the form of suggestions on improvements to the model as well as things I should be doing differently would be very much welcomed. The model is by no means perfect and my modeling clearly has some ways to go. You can tell from the render that the lips, and ears need to be improved upon. I'm having trouble with the corners of the lips and found that sculpting doesn't solve the problem; I may have to vert push to get the desired result.
