Gallery
Arc Reactor – Detail Pass 1 Final
This is the first detail pass on the Arc Reactor. Vert and Face counts are up to 270K & 240K respectively. Added the following: - cooling fis to top of reaction chamber - solder tabs to top of armatures - solder blobs to top of solder tabs - wires between armatures (still in array) - structural ridges around middle of reaction chamber - allen bolts near bottom of reaction chamber - increased spin resolution of rings holding the legs from 64 to 128 to remove edge artifacts - added detail to the plug Removed ground plane for faster render. 400 samples with AO in cycles. Update: Feb. 13, 2013 Model available for download on BlendSwap. http://www.blendswap.com/blends/view/66553
0 Comments
Add a Comment
