Why won't the water stay in my effector?
I’m using the blender 2.83 alpha build from 04/13/2020. I’m trying to keep the water in my cylinder I used as an effector in my mantaflow simulation like this video showed me https://www.youtube.com/watch?v=GqtuBCpxO0Q. I followed the steps I scaled the cylinder on the z axis and selected the top face and pressed I to make a new face on the top of the cylinder and extruded that face down and copied that face with shift+D and pressed P and selected to make that face it own object and extruded that face up to make the water and made sure to make the outside cylinder the effector and the inside cylinder the flow. But my water seems to go out and through my cylinder. Here’s a image of what happens in my blend file.
Here’s my blend file itself https://pasteall.org/blend/071d97cc132d4c97b0515c2fb63afab5. (edited I found out for some reason when I download my bend file from pasteall.org it will work all of a sudden and when I open the original blend file It will also work can someone maybe explain whats going on? )
