Question about output node compositing in *.exr format
Hi,
I outputed *.exr from output compositing node but I have a problem to put the image in the rgba standard exr format.
Somebody know how to name the output slot to get the image data in the primary rgba exr format ? As you can see below in the screenshot, the depth data want to be in first position but in the ouputed one is in 3rd.
Oki, so when I use an external denoiser like Altus for temporal denoising I put the right AOVs for beauty but in others application or in blender too, it's boring to not have the good rgba data in the rgba channel ;)
I need it cause I prepare in one template the two seed variation for sampling and output the two view layers in two different exr.
Thank you,
Matt
