Editing the cockpits inset/Viewport color
posted to: Modeling the Body
When I'm editing the vertices for the cockpit, they start to stick out a lot and make a big bump even with the subsurf. Is there something I might have missed? Also when you go to change the objects color in the view port (13:20) The "surface" into "settings" is gone. I'm using version 2.79.
EDIT: After some fooling around I fixed it. I must have shrink-wrapped the wrong object. I must have misunderstood something in the video or just mixed something up. (I shrink-wrapped the outer object to the model_block object to fix my problem.)
