substance painter project export map?
I noticed you did not use SP to make a Height Map. Why? When would you make one?
also, you redid the normal with a OPENGL normal. There was also a Direct-X normal. If I import using Direct-X, do I need to export using Direct-X Normal in the example?
Thanks
