Mesh Deform Problem - Solved
I had a problem with the Mesh Deform Modifier - but I fixed it.  I found that if I tried to set up the Mesh Deform modifier with the Mesh Def object deformed (the lattice modifier visible) then the results were off, or not visible.  So just a note, make sure you set up the Mesh Deform with an un-deformed Mesh Def object and you should be fine.     Needs some tweaking but I now have a usable eye!   This was a great course!
