beveling the button
posted to: Modeling the Sides
hi
every time I try to bevel the buttons it bevels with very minimal amount no matter how much I increase it,
I had a similar problem before but then applying scale worked now even that  does not work ?
Reply
  • Martin Bergwerf replied
    Hi Wahid wwr-116 ,
    Have you tried disabling Clamp Overlap (under Geometry in the Bevel Modifier)?
  • Adrian Bellworthy replied
    And have you checked for Double Vertices?
  • Omar Domenech replied
    And have you check for flipped Normals? Sometimes also the scale of your object is too big or too small and the values on the modifier can go into the decimal points.
  • wahid rehan(wr-116) replied
    yeah I accidently deleted the bevel modifier and forgot to turn of clamp overlap
