Editing standard Humanoid animations (?)
I needed a somewhat special Humanoid animation for my rig (precise walk and turn), which looked natural. I also needed to add a couple of "extra" coordinated items/bones.
It seemed theoretically possible to import FBX from a couple "Raw Mocap" clips into Blender, splice and edit, and re-export the result as a new FBX. It's a little tedious and finicky, but seems to be headed toward a good result. Easier than starting from scratch.
Is this something which is commonly done? Is there a better workflow for it?
Jonathan Gonzalez (jgonzalez)
If you feel comfortable working within Blender then I'd say stick with that, otherwise you could also look into using something like this: https://assetstore.unity.com/packages/tools/animation/umotion-community-animation-editor-95986. Editing animations can either be a quick process or a tedious process depending on what you're trying to achieve. It sounds like in your case you'd actually have to modify the animations quite a bit.
I'm not sure what you're trying to achieve, but if you're just blending between a walking/turning state you could use blend trees for that. This is a lesson that covers the process a bit more https://cgcookie.com/lesson/directional-2d-blend-trees. You can use blend trees to smoothly transition from various animation states for movement. I've used it to have a player run in any direction smoothly with just a few generic running animations.
Thanks
jgonzalez . UMotion looks extremely interesting - hadn't heard of it. With the Pro version I probably could do everything I'm attempting completely inside Unity. Probably a more streamlined process, although I am more familiar with Blender. In my case I was a little lucky, because I could just splice together ranges of standard clips and get pretty close.
I tried ranging/chaining standard clips and fiddling with transitions (the normal way in a Controller), and I can get in the neighborhood, but not as precisely or smoothly as I like. The required motions are really tight.
I've used add/sync layers somewhat in the past for adjustment. I completed the blend tree training but haven't tried constructing anything that way yet.
Hello, thanks for sharing this information. I am an app developer and want to share with you how to develop android app If you want to become an app developer then we will help you. So for more information please visit andromo website.
