Federico Violin (federicoviolin)
1 reply · posted
Problem in mechanical rigging
Hi to all, and I'm not so expert in using Blender.
I've some problem in apply a Constraint in the right way, related to an empty object.
The object is called "Spaceship - arm 01 rotator 01"; the empty object is called "Spaceship - arm 01 tracker 01".
I need when I rotate the empty circle, also the object rotate in the same way.
I think there's something wrong in the object axys, but I'm not sure...
And... what is the right way to add a simple blender project in this new versione?? :O
Thank you to help me!
Federico Violin
  • Perhaps I have the same question, or a related one.
    I have created an empty with a "Copy Rotation" constraint, and a circle as a target.
    • Target World Space <-> Owner World Space: works exactly as expected.
    • Target World Space <-> Owner Local Space: works exactly as expected.
    • Target Local Space <-> Owner World Space: target rotation (any axis) has no effect
    • Target Local Space <-> Owner Local Space: target rotation (any axis) has no effect
    I checked the documentation and I don't see any limitation to explain it.
    The Transformation constraint seems to behave similarly. I am obviously missing something.
    For "Copy Location", all combinations seem to work as expected.
