epet11
1 answer · asked · Lesson: Modeling Wood Details · Course: Modeling, Texturing and Shading a Treasure Chest in Blender 2.8
Bevel behaving strangely
I think this might be the same problem the other person asked about. The bevel is working in opposite directions on opposite sides of the planks that make up the top of the chest. In the pic below, you can see that the top and bottom left corners of the plank have moved outward, while the top and bottom right corners have correctly bevelled inward
    Hmm wonder what's causing that. Can you try recalculating your normals by selecting all mesh components in edit mode then pressing SHIFT + N.
    Also make sure your scale values are applied in object mode with CTRL + A then choose "Scale".
