lukesinclair
4 answers · asked · Lesson: Setup & Begin Painting · Course: Modeling, Texturing and Shading a Treasure Chest in Blender 2.8
When I increase the bleed it becomes uneven. I increased it with the side panel because I did not have the same options you had.
    I've not experienced this issue myself. Can't think of what could cause this...If you can get me your .blend file (via Dropbox link or similar file hosting service) I will take a look into the issue.
      Thanks for uploading your file for me to take a look at. But now I'm really stumped. Here's what the fill brush does for me with bleed set to 10 pixels with your file:
      Can you try again and see if the problem is still occurring?
      Also are you using the official 2.80 build of Blender?
  • I just reinstalled blender and it didn't work. What would you recommend I do next?
      As long as the spikes of grey don't overlap into other UV islands, it shouldn't be a problem. Definitely annoying that the issue is happening and not reproducible on my end, but you should be able to continue on. Again, just make sure the spikes don't overlap into other UV islands. If they do, try a bleed value of 5 rather than 10.
