karunnt
2 answers · asked · Lesson: Completing the Robo-Orb Retopology · Course: Introduction to Retopology
Can all poles be removed?
The one inescapable fact I see is that 'poles create artifacts', no matter how small or obscure the location.
Is it theoretically possible to remove all poles?
  • I have completed this assignment (although it still needs to be rated). I got a distinct feeling that i is not possible to avoid _all_ poles. Especially around the circular areas, you need to have a spot where you cannot avoid a pole.
    I have been able to polish away quite a few poles or move them to areas where they are less obvious, such as near a rim or a crease. While doing this assignment I did manage to retopo several poles away that I thought was unavoidable.
    For learning purposes, I can definitely recommend trying to retopo them away. I learned a lot about edge flow by doing that. I hope you do too
  • I found that poles allow you to remove edge loops without creating triangles or ngons. When you high density of edge looks in constricted area it can create artifacts.
