Where to find Multiball UI in Blender 2.80
I'm wondering if the UI panel is in some tab I haven't found yet or is it no longer available in the versions other than 2.77? I'm also having trouble finding the option "make proxy". It is not in the Object tab :/
Sorry for all these questions!
Wayne Dixon (waylow)
It has not been updated for 2.8
The UI stuff has changed, as well as 'collections', but it will all still work the same way.
I don't know if the file was updated since then, or if this is just how 2.8 works in comparison to 2.77(I started in 2.79)
But the Rig UI's is visible in the tool bar only when you are in pose mode.
In case anyone was looking for it still.
Hi Wayne, thank you for response. I'm stuck at the part where I have to make a proxy. Is there any alternative for that?
search with F3 (or spacebar - depending on your user settings)
Then type 'proxy'
You will see it there.
I don't think it has a hotkey anymore.
