How do I get the base mesh?
When I downloaded the project files, I opened a new .blend file and appended the "Cube" mesh from the start file. However, instead of appending the base mesh that you started with, it appended the result of this lesson. I would like to follow along from the very beginning, not the second lesson. Where can I download the base mesh?
Kent Trammell (theluthier)I chose not to include the basemesh for this project since I've taught the method so many times. If you look in the description you can see a list of links for how to create a basemesh like the one I start from. It should only take you 5-10 minutes to generate an equivalent one.
