shubham tripathi (shubhamaman)
3 replies · posted
Blender cycles material are not working in sketchfab
is there any other place to upload blender's cycle model.
  • How are you uploading the materials?  Are you using the plugin, or uploading on the website?  Give us a breakdown of the process to help understand your problem better.
    • I tried both he ways firstly by using the Addon and then directly on the website.
      First Attempt:-
      1.selcted the model in the viewport .
      2.Fill the various fields provied by the File/Io (sketchfab Addon) option likeTitle ,description,tag.
      3.paste the API key, and click on the upload
      4.and all i get is greyed out model in the sketchfab(no material applied that i used in blender's cycle render).
      5.I can even see my materials in sketchfab's 3D setting menu.
      6. I have not used any texture map here...except procedural texture like voronoi and wave.
      7.Link to sketchfab:-  https://sketchfab.com/models/f3739552a69d4dfc9fb44940c62911d4
      Second Attempt:-
      1.Exported to Wavefront(.obj) in the viewport.
      2.went to Sketchfab Website and Uploaded the OBJ and MTL file that i generated in step 1.
      3. but again the same result.
      4 Link :-https://sketchfab.com/models/2c8dc168d7c749399fd2a67b20507fad
      I  search for this on internet and people are saying that sketchfab  doesn't support Blende's Cycle material...if it is true..is there any  other option to uplaod the model
    • this is my model's snapshot. https://cgcookie.com/u/shubhamaman/projects/trishool
