I don´t know how to accomplish the cone figure
I am trying to compelte the cone figure but i am not able to do it. How to do the top part? I can not make a bevel in an vertex. I can not make a loop cut becaue the faces are tris.
Is there no option to have a live chat support?
Jose Vergara (calmadigital)Ok, i got it at last how to do the cone figure. 2 hours strugling with it.
care to explain? struggling here
Do you speak spanish? It could be easier for me.
I used the knife tool to cut through the model, then dissolved the top vertex. Then play around with the different tools to achieve some interesting shapes
The trick to doing the cone is to do a Vertex Bevel on the point via CTRL+SHIFT+B.
The way i do it is:
Select the top vertex -> Ctrl+B -> Left Click -> F6 -> Segments to 1 -> Check "Vertex Only" -> Adjust the Amount.
And you're happy ;)
