How to disconnect(dissolve) edge between vertices
Is there a simple way to disconnect or dissolve edges in between vertices while keeping the vertices so that it would end up like the image below?
I tried everything I could think of, but the corner squares would always end up being triangles.
I eventually got the desired outcome, but just by chance (first beveling+indenting the corners and then deleting the marked edges).
But I am still curious if this is something possible. Just feels better cleaning up beforehand than afterwards..!!
Certainly!
You can do this by selecting the cross-section of faces and then pressing F to Make Face, which will convert the selection into an NGon.
Before: https://cl.ly/rFKT
After: https://cl.ly/rEiS
