tonycam123
2 answers · asked · Lesson: Vanilla Ball Bounce · Course: Blender Animation Bootcamp
File starts up with basketball, when i change it to blue paintball, it switches back to baskett ball when frame changes. How can i keep it on paintball?
    It sounds like you have a keyfame set on that property and when you are changing frames it is updating to the keyed value.
    if you don't want it to change, 'clear keyframes' on that 'ball_type' property (right click > clear keyframes)
  • I had the same problem and I just realized what the issue is. When you open the exercise file, there is a message at the top of Blender saying "Auto-run disabled". And if you press "Reload trusted" the ball will become the plainball automatically.
