apply scale/rotation/... and Curve modifier
Hi,
Just because i'm used to work that way, I like to reset my scale and rotation when working.
I did this with the hair mesh and hair curve (before applying the modifier), but it acts weird; it does not match.
I need to give the mesh X -90° & Z -90°.
Do you understand why ? If they have the same scale, origin and rotation; why don't they match ?
Working with curve modifiers is always a bit finicky and honestly I have to tweak it every time I use them.
If in doubt, just ensure the origins and transforms match between the curve and mesh. Beyond that I'd recommend simply using what works, even if it seems wrong.
