Michael Morrow (mtmorrow)
1 answer · asked · Lesson: Glossy Reflection · Course: Fundamentals of Shading
How do i access the gizmo texture file?
The gizmo texture is not part of the exercise files How can i access it?
    mmtmorrow - The gizmo's textures are "packed" into the .blend file, meaning they're included. So when you go to add the texture it's simply available in the drop-down instead of importing the texture file externally.
    Can you confirm that the gizmo textures are available in the texture select list of the image texture node?
