David Frazier (pointoflife14)
2 answers · asked · Lesson: Implementing Absorption · Course: Shader Forge
Kent, what file is it that has the basic crystals as seen in the bottom right hand corner of the UI (in the beginning of t...
Kent, what file is it that has the basic crystals as seen in the bottom right hand corner of the UI (in the beginning of this video)? There are a lot of downloads that say 'source files" but it's hard to tell which one contains this startup blend file with those crystals. Can you clear this up bro? Thanks
