koolsamhits
1 answer · asked · Lesson: Rig Hierarchies · Course: Fundamentals of Rigging in Blender 2.7
How can you rotate the plain axes above the blade? You just duplicate and rotate around z 72 degree. But it never work on ...
How can you rotate the plain axes above the blade? You just duplicate and rotate around z 72 degree. But it never work on mine. The plain axes always rotate around itself.
  • https://wiki.blender.org/index.php/User:Fade/Doc:2.6/Manual/3D_interaction/Transform_Control/Pivot_Point/3D_Cursor i had that same problem. you have to set the 3d cursor to the selected object (the rotor hub) using the hotkey shift s, then you use the hot key . to set that as the pivot point, and then you can duplicate and rotate along the z axis (i think z..)
